Just about done doing the final check on the wiring for my truck. But the same issue keeps nagging at me.
The truck is a 46 with all original gauges, switches, 6 volt etc. The harness is from Jim Carters.
The diagram from Old Online Chevy Manuals shows a wire from BAT on the voltage regulator to the ammeter then to the light switch.
The harness skips the ammeter and goes from the BAT to the light switch.
Do I need a jumper in there?
Thanks, Aaron
