7 members (mason86, Phak1, klhansen, tclederman, Ponchogl, dt235sd, Hanks custodian),
70
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,672 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Thanks Joe, the bolt and washers suggestion worked fine. I have used a similar idea for removing items but it just never occurred to me to use that technique to draw the bushing in.
There is no way to get at the backside of the worm shaft bearing races. Anyway, if I look at them without my glasses they look perfect. Actually the inner races on the worm gear have more marks and I am not going to replace that entire shaft so I might as well use the old outer races too. They really are not bad, just that I know it would be better to have the new bearings in new races.
Chuck | | |
