| | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The least expensive would be to locate a FREE 3:55 ratio car rear end say, 1951-54. These were in cars with the powerglide trans. I have a tech tip on this you can check out. The very best way is to ditch the torque tube and go open drive line and then a zillion better ratio rear ends could be used. | | |
