0 members (),
129
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62827 07/10/2006 5:07 PM | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | I am running an 11 inch clutch behind my 261. It is tight. In fact when installing it the pressure plate rubs against the bell housing while you are tightening it up but once it is torqued down it works fine. I have put thousands of miles and a number of trips down the drag strip without a problem. I assume you must have the flywheel drilled for the 11 inch clutch and if so it should work fine. | | |
