Not sure on the 230 & with the holiday this is a bad time for a quick answer. There are lots of folks here with your engine that will be able to help with specifics but they may not check the forum until tomorrow sometime. One of the best things you can do is to purchase a manual for your truck. eBay is a good source for manual reprints. Good luck.
