The number of teeth on both starters is the same. The difference is the angle of the teeth on the starter shaft. If you look closely, you can tell there is a difference. There may be some other differences in the units that will more easily identify what the unit is for, but counting the teeth isn't going to answer the question.
That's all there is to it!
Joe
