| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Powerwagontim, when you converted it to 12 volt, what type of coil did you use? There are coils that are made to use 12 volts all the time, and others which must have a ballast resistor installed in the circuit before the coils primary connection. If you use a coil which requires a resistor, without a resistor, the coil will overheat and break down, the engine may idle fine, but will misfire more and more if you can get it to rev up. Check what type of coil you have, and either replace it with one that can be fed 12 volts all the time, or install a ballast resistor in the coils primary circuit. The only other thing that I can think of that may cause the problem you have is a bad condenser, good luck. | | | |
Entire Thread
About at my wits end, getting an engine to run
| Powerwagontim | 12/10/2009 5:11 AM |
Re: About at my wits end, getting an engine to run
| MikeE | 12/10/2009 5:21 AM |
| Mikestem | 12/10/2009 5:55 AM |
| 3B | 12/10/2009 6:33 AM |
| glasman | 12/10/2009 1:05 PM |
| Daniel Bland | 12/10/2009 1:07 PM |
| Powerwagontim | 12/10/2009 1:13 PM |
| Hotrod Lincoln | 12/10/2009 1:50 PM |
| Builder | 12/10/2009 2:37 PM |
| 3B | 12/10/2009 5:03 PM |
| Justhorsenround | 12/10/2009 6:40 PM |
| Harvester | 12/10/2009 6:41 PM |
| Builder | 12/10/2009 10:02 PM |
| 61nate | 12/12/2009 12:35 AM |
| Powerwagontim | 12/12/2009 3:20 AM |
| Tomcoe | 12/12/2009 6:01 AM |
| Tomcoe | 12/12/2009 6:12 AM |
| Mike B | 12/12/2009 11:37 AM |
| crenwelge | 12/12/2009 6:54 PM |
| Wrenchbender Ret. | 12/13/2009 12:32 AM |
| Hotrod Lincoln | 12/13/2009 3:15 AM |
| crenwelge | 12/13/2009 5:08 AM |
| Wrenchbender Ret. | 12/13/2009 4:01 PM |
| 65 WonTon | 12/13/2009 5:56 AM |
| glasman | 12/13/2009 4:06 PM |
| crenwelge | 12/13/2009 6:17 PM |
| Spareparts2 | 12/13/2009 7:02 PM |
| Wrenchbender Ret. | 12/13/2009 11:00 PM |
| Roy Rodgers | 12/13/2009 11:41 PM |
| Builder | 12/14/2009 6:45 AM |
| sask42 | 12/15/2009 5:29 AM |
| PapaJ | 12/15/2009 8:00 AM |
| Powerwagontim | 12/17/2009 1:25 PM |
| Repair | 12/17/2009 3:23 PM |
| Builder | 12/17/2009 9:28 PM |
| Powerwagontim | 12/18/2009 2:44 AM |
| Powerwagontim | 12/18/2009 3:01 AM |
| Tomcoe | 12/18/2009 3:04 AM |
| sask42 | 12/22/2009 1:44 AM |
| to_many_irons | 12/28/2009 9:57 PM |
| PapaJ | 12/29/2009 9:38 AM |
| to_many_irons | 12/30/2009 4:17 AM |
| sask42 | 12/31/2009 5:27 AM | |
