0 members (),
133
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Sooty plugs says rich, but it's hard to argue with a carb. swap not changing conditions, unless the "old Chevy" carb had the same issue. I think the '50s 235s used a Rochester carb with a vacuum port in the manifold - is this there and open?
Popping and backfiring sounds like timing. I agree, test the vacuum advance (I got a Mighty-vac kit at parts store, very useful and not that expensive).
Can you swap out the coil and the condenser also to rule these out?
Does it consistently idle ok? Just faulters at mid or higher rpm?
-Michael | | | |
Entire Thread
About at my wits end, getting an engine to run
| Powerwagontim | 12/10/2009 5:11 AM |
Re: About at my wits end, getting an engine to run
| MikeE | 12/10/2009 5:21 AM |
| Mikestem | 12/10/2009 5:55 AM |
| 3B | 12/10/2009 6:33 AM |
| glasman | 12/10/2009 1:05 PM |
| Daniel Bland | 12/10/2009 1:07 PM |
| Powerwagontim | 12/10/2009 1:13 PM |
| Hotrod Lincoln | 12/10/2009 1:50 PM |
| Builder | 12/10/2009 2:37 PM |
| 3B | 12/10/2009 5:03 PM |
| Justhorsenround | 12/10/2009 6:40 PM |
| Harvester | 12/10/2009 6:41 PM |
| Builder | 12/10/2009 10:02 PM |
| 61nate | 12/12/2009 12:35 AM |
| Powerwagontim | 12/12/2009 3:20 AM |
| Tomcoe | 12/12/2009 6:01 AM |
| Tomcoe | 12/12/2009 6:12 AM |
| Mike B | 12/12/2009 11:37 AM |
| crenwelge | 12/12/2009 6:54 PM |
| Wrenchbender Ret. | 12/13/2009 12:32 AM |
| Hotrod Lincoln | 12/13/2009 3:15 AM |
| crenwelge | 12/13/2009 5:08 AM |
| Wrenchbender Ret. | 12/13/2009 4:01 PM |
| 65 WonTon | 12/13/2009 5:56 AM |
| glasman | 12/13/2009 4:06 PM |
| crenwelge | 12/13/2009 6:17 PM |
| Spareparts2 | 12/13/2009 7:02 PM |
| Wrenchbender Ret. | 12/13/2009 11:00 PM |
| Roy Rodgers | 12/13/2009 11:41 PM |
| Builder | 12/14/2009 6:45 AM |
| sask42 | 12/15/2009 5:29 AM |
| PapaJ | 12/15/2009 8:00 AM |
| Powerwagontim | 12/17/2009 1:25 PM |
| Repair | 12/17/2009 3:23 PM |
| Builder | 12/17/2009 9:28 PM |
| Powerwagontim | 12/18/2009 2:44 AM |
| Powerwagontim | 12/18/2009 3:01 AM |
| Tomcoe | 12/18/2009 3:04 AM |
| sask42 | 12/22/2009 1:44 AM |
| to_many_irons | 12/28/2009 9:57 PM |
| PapaJ | 12/29/2009 9:38 AM |
| to_many_irons | 12/30/2009 4:17 AM |
| sask42 | 12/31/2009 5:27 AM | |
