...mine has a small set screw I take out and drop in a few drops...but as someone said, just put some in the air intake and it'll find its way to the right place..... It will probably spit oil out for a while depending on how much you put in it. Usually about 3-4 drops once a week is ok unless you use it a LOT then do it two or three times a week.
