| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57935 03/21/2006 4:58 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Ditto on the "replace tank" info. I just went through the "salvage" process. If it's got holes you've found there are a lot more lurking in spots yet to be discovered. A "restore" kit is $44. and a new tank is $129.00 from CD. Just be sure to use the correct color of teflon tape to seal up the drain plug. Several posts complain of leaks from drain plug. White tape is not designed for petroleum based liquids. I think the fuel-grade teflon tape is yellow. Just my $.02....because... | | |
