| | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57932 03/18/2006 9:50 PM | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Well I went out to look at removing the broke off petcock on my gas tank when I noticed...while inspecting closer in better lighting...PINHOLES where I had wire brushed rust of the outside of the tank. While probing around the entire tank pretty hard with a sharp poker to check the integrity of the metal, I found about 6 pinholes. I really want to keep this original tank in the truck. Is there any way I can fill these holes and then coat the inside to make it stronger and prevent other holes? If I can fix them, I was planning on treating the outside of the tank with POR15 or something that will give a nice rock hard finish and stop the rust. What would you do???
Chris Simmonds 1942 Chevy 3/4 ton | | |
#57933 03/18/2006 11:44 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Chris I would buy a new tank. You can get one for about 200 bucks and not worry about rust for the next several years. Sometimes it is better to go new than try to salvage the old especially when your safety is at hand. Juat my .02 worth. | | |
#57934 03/19/2006 12:07 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree. If a new one is available that is the best way to go. If not take it to a radiator shop that does gas tanks. They can clean it & solder any leaks. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#57935 03/21/2006 4:58 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Ditto on the "replace tank" info. I just went through the "salvage" process. If it's got holes you've found there are a lot more lurking in spots yet to be discovered. A "restore" kit is $44. and a new tank is $129.00 from CD. Just be sure to use the correct color of teflon tape to seal up the drain plug. Several posts complain of leaks from drain plug. White tape is not designed for petroleum based liquids. I think the fuel-grade teflon tape is yellow. Just my $.02....because... | | |
#57936 03/21/2006 9:16 AM | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 |
#57937 03/21/2006 10:53 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Too bad you are in Oregon. I have one in my garage I would give you! | | |
#57938 03/21/2006 3:27 PM | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | 46 In Progress,
Would you consider shipping it to me? I'm currently using a boat gas can in my 39. I'd really appreciate a correct gas tank, even with pin holes.
Thanks, | | |
#57939 03/21/2006 4:20 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If they are truly just pin holes they will be easily fixed by using Redkote tank liner or another simular product. If they're much larger than a pencil lead they should be brazed shut first. The is no reason you cant re-use your original tank just because of pin holes. If you choose to clean and re-line your tank be sure to follow the instructions to the T. Those that complain about tank liners failing are those that didn't follow instructions. I've used Kreem and Redkote on different vehicles and much prefer Redkote. I buy it locally at a Bumper-To-Bumper jobber but you should be able to order it from about any parts house.
#57940 03/21/2006 6:17 PM | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | 46 in Progress,
Thanks so much for the offer. Man I wish you were closer.
Tiny,
THAT is the answer I was hoping for. My tank, although there is some pitting and a few pinholes, seems much to nice to just throw away and replace with some new plastic tank. The whole idea of rebuilding and restoring my truck was just that....to rebuild and restore each part back to servicable condition. It is enjoyable to take a part (or a whole truck for that matter) that some would consider "junk" and bring it back to life both cosmetically and functionally. I dont know, maybe I should replace it with a new tank and maybe that would be the safest thing to do, but money is somewhat of an issue and I would prefer to rebuild and save as much as possible. Thanks for all the help.
#57941 03/21/2006 7:21 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I found about 10 pinholes in a 3"X 3" area and about 4 others where the strap covers it.First I put a bag of sand in the tank and shook it and turned it for about a half hour. Then I cleaned it by shaking it around with water til nothing came out of it any more. The area around the outlet for gas had the cluster so I got a piece to cover that spot and welded a new pipe in the middle and welded the patch on. I then spot welded the remaining pin holes.The bottom and the welded pinholes are not visible so after letting it dry in the sun for an hour, I painted the tank, total cost maybe $15.00 and 2 hrs work. It looks great in the truck and it does not leak. I have to save money any way I can. How much time would it take to arrange and pick up a new one/cost? How much time/cost would you have to invest in another used one? You pick, it all depends on what your needs are,in my case I want to spend my money on my family and home.My truck is just my hobbie and what I like, is doing the work .The second it's finished I will drive it and sell the last one, so I can build another one, that's part of the fun.I usually have a driver and as soon as I finish my project ,I sell the one I drive. | | |
#57942 03/27/2006 1:00 AM | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Hey Fla54chevy3100, Just read your post. I never knew teflon tape came in anything but white. Can you get the yellow you mentioned at any auto parts store? That woud sure clear up several of my problems. Thanx
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#57943 03/27/2006 2:24 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I know yellow is used for natural gas. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#57944 03/28/2006 9:21 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | you can spend the money fixing the old tank or spend the money on a new one iv found the new one is the way to go | | |
