| | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | ..... Since I intended to pull the axle's to replace the torque tube with a later pumpkin and put in new grease grease seals and doing the brake job, I blasted mine with the rear end on it. Then I pulled the torque tube and flushed everything. I also left the front axle on it as I was pulling everything off the front spindle as well. So, I guess it would depend on what your "next move" is planned to be. Each situations may very.
