10 members (TUTS 59, Jay R, DadsFirstPickup, Ponchogl, GradyB, Leo, Jon G, walterhvogel, JW51, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The updraft carbs have only about a dozen parts. You could easily rebuild this yourself, the only adjustment being the float height and where the clip sits on the piston inside.
Im sure I could come up with the measurements for the float if you need. You can spend $40 on a kit, but the only replacable parts are a needle/seat and a gasket. Maybe a small spring or two. These really are about as simple as carbs come.
Jeff | | |
