| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brand of engine (GMC or Chevrolet)? Size of engine? Year of engine? Optional 216/235/261 by-pass oil filter Tech-Tip - if you have a GMC, the plumbing (at least) will be different. High-pressure 235/261 full-flow conversion (does this work on a low-pressure 216/235??) - if you have a GMC, the technique might be different? If you have a GMC 228/248/270/302, information on the full-flow upgrade can be found at oldGMCtrucks.com | | |
