1 members (1 invisible),
108
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I used a 79/80 Malibu rear end in my 37. It does fine. I just set the pinion angle and then welded the perchs. It sits right on top of my original springs, used tube shocks and it rides pretty doggone good. I had to move it about 1 1/2" to get in in the center of the fenders. I make a "plate" and drilled a hole in it to fit over the center pin on the original springs, then drilled a hole for the lowering block's center pin to fit in... then the rear end sit on top of the lowering block with the hole in the perch fitting on the center pin of the lowering block..... gosh, I'm probably confusing you but this is how I did mine. If you do not need to lower yours then just leave out the lowering block. | | |
