Trucked Up:
If you have NOTHING then I may be able to help you out. I have several pieces that I bought from another bolter, Spanky, some time back because I figured they would be hard to find.
I think I have an extra middle "mechanism" along with the handle that goes with it. I "think" I may also have an extra top or bottom latch that goes inside the door. I will just have to look and see.
I do not have the two rods that go to the top and bottom BUT I have one that the threads twisted off of that you could use as a pattern. They are not hard to make as I had to have one made myself. I would have repaired the broken one but I kept it as a pattern....for future use. I can give you the exact length.
Are you in a hurry for these??
*** Do you have a parts panel around your area? I could use a better "catch" that attaches over the left door to the body. Its sort of triangular...... as well as a filler between the rear bumper and body.
EDIT:...for comments about the rods.
