| | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | this release brg has been working in there for how long now; 100,000 mi.?.thinks do wear out. there is more than 1 place for wear in this setup and you can lose quite a bit in linkage wear. if trhe clutch disc is worn out , one should always replace th p/p at this time as it's surface also wears and it doesn't necissarily wear flat and springs can loose tension..the biggest PITA is replcing it after you find out that it isn't as good as youi thought it was.there are 2 different depths of t/o bearings depending on style of p/p. whether or not that it is a diaphram or 3 finger setup don't be cheap as it will more than likely cost you more in the end ron | | |
