Can one of you guys confirm that a NAPA Auto Parts '49 water pump, part number WP 58125, will work with the relocation plate? Go to www.napaonline.com and type in the part number. I already bought the wrong pump once, and I don't want to do it again. My main questions relate to shaft length and bolt pattern at the relocation plate. I'll check the bolt pattern for the fan before I buy it.
