I don't know how much more performance you think you will get that makes it worth while. I would just rebuild what you have for a carb. They are reliable and simple. If you are trying to get away from points (cheapest way), then a costly electronic ignition is the answer. Colletsbro will most likely have a stock radiator for you.
