| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | The mixture screw only works at idle, to change off-idle mixture you will need to re-jet. I would get some miles on it before worrying to much. It could be loaded up for all the tuning you have been doing. Get a HEI or new points distributor, get it timed where it doesn't ping under a medium load (6-10 degree) then get it out on the highway. A good 10 mile drive will clean out a lot crud and dry out the plugs. If it still smokes, we can go from there. Joe | | | |
Entire Thread
HELP, HELP, HELP
| mswilkes65Chevy | 04/07/2009 11:29 PM |
Re: HELP, HELP, HELP
| 3B | 04/08/2009 12:53 AM |
| mswilkes65Chevy | 04/08/2009 1:23 AM |
| hoggyrubber | 04/08/2009 2:35 AM |
| mswilkes65Chevy | 04/08/2009 2:43 AM |
| mswilkes65Chevy | 04/08/2009 12:38 PM |
| hoggyrubber | 04/08/2009 3:15 PM |
| mswilkes65Chevy | 04/08/2009 3:16 PM |
| Builder | 04/08/2009 4:22 PM |
| mswilkes65Chevy | 04/08/2009 5:16 PM |
| RED65STEPSIDE | 04/08/2009 8:10 PM |
| mswilkes65Chevy | 04/08/2009 8:50 PM |
| Hotrod Lincoln | 04/08/2009 9:41 PM |
| mswilkes65Chevy | 04/09/2009 1:00 PM |
| Wrenchbender Ret. | 04/09/2009 1:49 PM |
| mswilkes65Chevy | 04/09/2009 4:58 PM |
| Wrenchbender Ret. | 04/09/2009 5:17 PM |
| mswilkes65Chevy | 04/10/2009 1:01 AM |
| Daniel Bland | 04/10/2009 1:38 AM |
| mswilkes65Chevy | 04/10/2009 1:36 PM |
| Joe H | 04/10/2009 3:05 PM |
| mswilkes65Chevy | 04/13/2009 12:22 AM | |
