This linkage to the manual valve, I'm not sure I understand what you mean about installed wrong. The pan and fluid were clean, pump is in correctly, as I didn't actually take the pump apart, just cleaned it. I think I need the torque specs for adjusting the band, as in how tight is tight when bringing it in, like in inch-lbs, maybe? And then how far to back it out. Some of what I read says it can do what it's doing from it being out of adjustment. I installed the bellhousing bolts first, so that shouldn't be a problem. I think (can't remember for sure) the convertor spun freely before I put in the bolts to the flexplate.
If I can't get it working, I'll ask you about what he wants for the one he has, I could probably come pick it up if need be.
Meh, can't work on it again until Wednesday, anyways, post shop weekend is Monday and Tuesday.
Thanks again,
Tony
Wide open 'til you see God...
Then brake
'64 Stepside 355, 700R4, 10:1 C/R, TCI Streetfighter, Thumper Cam, Hedman Hedders, starting wiring and bodywork shortly, W.I.P.
'07 Charger 3.5L
'99 Dodge Ram 1500 Ext. Cab 360 4x4 (Sold)
'07 F@#$ Focus ST (Sold)
