| | | Forums66 Topics128,052 Posts1,055,771 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | hi
i'm rebuilding my carb. the accelerator pump was not working.
after soaking it, the small passage that the gas should squirt out of into the throat of the carb is plugged. i can see the outlet but can't find the inlet in the accelerator pump discharge. according to my manual it looks like the inlet is very close to the top where the spring stop is press fit. is it possible that the swaged alluminum would cover the small hole? am i looking in the right place?
