| | | Forums66 Topics128,140 Posts1,056,776 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi Fellow Stovebolters, I am working on a 1946 Chevrolet model DS 1-ton Panel truck. I want to change the gear ratio in the rear end from its present 5.14 ratio to a higher 3.90 or 4.11 ratio. The research I've done tells me they used the same rear end in 1946-1960 Chevy 1 ton trucks. Can anyone tell me if this is a Dana rear end and if yes what model? This unit has a pumpkin that can be removed as well as a rear cover plate. Thanks in advance! Brian [email protected]949 973-6224 | | |
