4 members (37 GC, IHPWR, Hotrod Lincoln, NJC), 141 guests, and 2 robots.
Topics128,141
Posts1,056,780
Members48,454
old truck heaven
old truck heaven
Hi Fellow Stovebolters,
I am working on a 1946 Chevrolet model DS 1-ton Panel truck. I want to change the gear ratio in the rear end from its present 5.14 ratio to a higher 3.90 or 4.11 ratio. The research I've done tells me they used the same rear end in 1946-1960 Chevy 1 ton trucks. Can anyone tell me if this is a Dana rear end and if yes what model? This unit has a pumpkin that can be removed as well as a rear cover plate.
Thanks in advance!
Brian
[email protected]
949 973-6224
I
I Offline
It's a Eaton rear end. A pumpkin from a 68-72 3/4 ton should swap out directly.
You could find a 4.10 or more likely a 4.76, 3.90 will be near impossible to find.
I've got a 46 DS pickup, where you at in California? You could check out my T5 behind a 235. I decided to keep the 5.14 rear end and use a .63 o/d. Works out to be a nice combo.
Greg
old truck heaven
old truck heaven
Hi Greg,
Thanks for the reply. I like that idea. I have a 235 engine also .....and I could still have the low ratio if needed. I started looking for a 1967-72 3/4 ton rear end today.....just may have found one. I live in San Juan Capistrano,CA ( southern CA). I did find that the 4.76 is easy to find....but am holding out for a 4.10
Brian
I
I Offline
Hey Brian,
Also ping Dave Murry out in Florida. He has a DS Suburban that he just did a full rear end swap. It costs a bunch more but you'll get to pick the ratio that you want.
If you keep at it you'll eventually find a 4.10, best of luck.
Greg
