| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 17 New Guy | | New Guy Joined: Jun 2007 Posts: 17 | The difference in bolt pattern in that the center 2 bolts are on a different angle due to the riser for the throttle body. A cheap way of fixing this is to elongate the center 4 bolt holes. Add some pipe sealant so that oil will not be pushed up the threads. Edelbrock will make a carb intake for the TBI heads. You will still need a external fuel pump because the block does not have a place for it. | | |
