7 members (55shaker, TexasA&M48Truck, MickeyP, Ponchogl, Hotrod Lincoln, Nick in Manitou, 1 invisible), 126 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#506648 02/16/2009 11:55 PM
Where can I get an intake for a 87 350? As it is now it is a tbi I want to change to carburated.Who makes these intakes? Is it a simple swap?
derry #506669 02/17/2009 12:39 AM
This is a swap I've never done. Most folks are going the other direction.
In THEORY, you could do it. An Edelbrock intake should bolt right in. I think you'd have too much pressure from your existing fuel pump.
Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
BlueDawg #506694 02/17/2009 1:34 AM
I woulk keep it fuel injected but, I have the orig. tank as I understand it I would have to change tanks for some kind of return line.
derry #506766 02/17/2009 3:57 AM
Not sure what your application is. If your heads are centerbolt 64 cc you will have a good street motor. Your heads might be Vortecs. Edlbrock sells a Vortec specific intakes. If you have hood clearance use an RPM airgap. If you are on a budget there are other manifolds out there made overseas. They are knock-offs and are decent but you will have to run a thread chaser through the holes where the carb and accesories bolt up.
Simple swap-- depends on your mechanical ability.
Disconnect battery
Pull the distributor. Put your engine in TDC.
Pull the alternator
Pull the Power steering pump
Pull the water pump
Pull the water outlet and associated hoses. Little tip cut the hoses at the outlets, makes it easier to pull and not bust a radiator or ?
If you have the $$$ replace them all, hoses, belts, Alt, WP, PS, Water outlet, Thermostat, PS hoses.
Put engine on TDC and pull the distributor. Pay attention to where the dizzy is in respect to the manifold. Look at where the rotor is pointing and mark the cap and base of the dizzy. Do not turn over engine. Also a good time to replace plugs, dizzy cap, rotor, SP wires. When you stab the dizzy place white grease on the dizzy gear. When you restab it make sure the round gasket at the base of the dizzy is in good shape. You may have to make several attempts to make sure the dizzy and the oil pump cog line up.
Use good gaskets - Felpros. Only put RTV on the water inlets, the outer most square ports. pay attention to tightening sequence and torq values..11 lbs I believe.
I would use a Holley 650 or 600. Good carb. Edlebrock carbs are fussy to about fuel pressure. If you change out the cam.. It's a whole new ball game.
Project Helen #506860 02/17/2009 12:32 PM
87's are not the famed "vortec" heads. Those are '96-2000 truck heads unless someone swapped them.
If you keep it EFI - you need to either have an external fuel pump with a return line to the tank, or you can simply create a fuel reservoir where the in-tank fuel pump sits in and you run the return to that. do a google search on EFI conversions, or check out www.jagsthatrun.com and buy their book.
I have done EFI swaps a few times. If you need more pointers, PM me.
Scott Danforth #506864 02/17/2009 12:51 PM
Thanks for the info guys.I am sure I will have more questions
derry #507195 02/18/2009 4:32 AM
The difference in bolt pattern in that the center 2 bolts are on a different angle due to the riser for the throttle body. A cheap way of fixing this is to elongate the center 4 bolt holes. Add some pipe sealant so that oil will not be pushed up the threads. Edelbrock will make a carb intake for the TBI heads. You will still need a external fuel pump because the block does not have a place for it.
1950 GMC 3100
Camaro frt clip, 4 link, 6.0L, 4L65-E
More pix on Photobucket
Nthstr #507515 02/19/2009 1:11 AM
1 Offline
Elongating the bolt holes works fine. We have done it many times.
