48erchevyman: One or two guys have used a colum out of a 68 which I'm looking at doing. It leaves the switch in the dash but has turn signal lever. I also like it cause its small/trim. But of coarse you have to cut the shaft to fit but from what I read here it is not such a big deal ??
What part of S.C. or you from? I sent you an email and hopefully you can join the Second Southern Stovebolts Reunion in May in Spartanburg.
Edit: Welcome to the Stovebolt!!!
