Won't deteriorate rubber seals and other parts (did you notice the part about Won't deteriorate rubber seals and other parts
Thats the issue. There are about 761 million types of rubber, give or take a few. It comes in every grade imaginable. Some can take gas or solvents while others will gel into nothing in no time flat when exposed.
So the ultimate question is to know whether or not your seals are compatible between the different products available.
