The pointer mount on the one that I am working on turned up and then the pointer came came back down from the top a picture is worth a 1000 words. http://good-times.webshots.com/photo/2291283390103315458YynGWM I need to lengthen the one sitting on the top of the pointer (from a 60's GMC) arm in the photo but am not sure how long it needs to be. You have a photo in your webshots of the tuner from the front after you put it back together without the bezel on it yet that shows the pointer. If I had that jpg I could scale it in photoshop to actual size by comparing it with a known distance from my tuner. Then I can get the measurement from your photo of the length of the mounting part of the pointer. I will have some perspective to compensate for but I think I can get real close. It would also give me some idea as to weather the knobs are in the correct position from top to bottom. What I need is that photo but if I download it from your webshots I can't doo anything with it. I hope this makes some sense. Thanks Neil
