Yep,I meant CAB mount.Looking at the picture,you could slightly bend the linkage so it isn't dragging or binding.
There is a bolt or cotter key holding the gas pedal to the linkage(Check to see if it is there).under the hood there should be a cotter key holding it in place next to the bellcrank stud in the block.
Take those points loose and pull the linkage out,then you can slightly bend it.Lube all the pivot points including the stud .
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams."
