I haven't done it but have heard how. Heat the flywheel in a BBQ grille. Then quench the flywheel with water and the ring gear should pop off. Then heat the new gear and put the flywheel in a freezer for a few hours. Then assemble new gear. Don't know if it works but sounds like it would. Hope this helps.
