Jerry........
I had the local carby guru modify a Q-Jet that ran at 900 cfm,
The performance/economy was way superior to what I could get out of a Holley, but the only let down was the small fuel bowl of the Q-Jet.
Over the course of a high speed run, it would simply run out of fuel!I must admit that the stock mechanical fuel pump probably did'nt help the situation.....have you had this problem on an engine before?????????
