I am getting ready to install the pressure plate assembly back on a 235.
Chevy manual says to be sure to line un marks on the outer shell of the pressure plate assembly with the same mark on the flywheel. I am NOT asking about mark on the shell with the mark on the pressure plate.
Can someone tell me where the mark is on the pressure plate shell? I found the mark on the flywheel. I do not know if the pressure plate assembly is stock or a replacement. It looks to be in quite good condition with very little rust on the outer shell. Pressure plate shows very little wear. Clutch disk still has some very faint identification marks on the surface.
Bob
