| | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Most of the after market companys sell oil pressure rubber lines(grease gun line) that goes from the oil filter to the motor. The openings are very small on the lines. If i make up some larger diameter lines, will this cause the oil pressure to drop dangerously low? Bigger lines with more flow will filter the oil better, but not at the expense of the engine. Cecil............ | | |
