| | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Most of the after market companys sell oil pressure rubber lines(grease gun line) that goes from the oil filter to the motor. The openings are very small on the lines. If i make up some larger diameter lines, will this cause the oil pressure to drop dangerously low? Bigger lines with more flow will filter the oil better, but not at the expense of the engine. Cecil............ | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It will lower the oil pressure. The regular lines work fine. These are bypass filters. All the oil eventually goes through it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
