It is an adaptation of a Blazer tank to a pick-up, some fabrication is required. The straps are just bent so they fit in the box for shipping, nothing is pre-bent to fit the tank. I made a "framework" for my tank so that it's supported on all four edges instead of just by the frame rails. My truck is a 4X4 so the box will sit a little higher off the frame and I'm putting in a steel floor from a rust free 89 C3500 I got. I'm not sure what mod's I'll have to do, if any, to clear the top of the tank with the bottom of the bed. I'm also undecided on how I'm going to fill the tank. I may graft in a filler door into the side of the body or a filler door on the inside of the bed. I definately don't like the ones in the floor.
Scott
