| | | Forums66 Topics128,056 Posts1,055,792 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40931 08/09/2004 7:37 PM | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | Frist thing to do is put the thermastat back in. Drill a 1/16 hole in the flange of the thermastat and this will allow the air to get past the thermastat. The STAT will help to regulate the flow of your cooling system.
When you fill the Radiator. When do you stop filling? Where is the coolant level when you stop filling it?
Next when you run/ drive your truck what temp is the gauge reading?
Are you using straight water or a mix of water and antifreeze?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
