1 members (KEVINSKI),
96
3
Mod | | | Forums66 Topics128,099 Posts1,056,506 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are not hard to rebuild as far as transmissions go. You will need agood set of snap ring pliers & a press. Changing to a 4 speed does not change the final drive ratio & would be more work changing the floor plate. If the noise in in the lower gears & is quiter in high it probably is brg. noise. You can put ring & pinion gears from a 50-54 pass.car with powerglide in the rear end to get better highway driving. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
