8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count),
46
0
Mod | | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BC52,
I have seen this happen. It's almost like the HEI module isn't getting enough voltage while the starter is gobbling it up as it cranks, but when you let go of the key, there is now enough for the distributor and it leaps to life.
I don't think it's the key switch but it could be a failing HEI module.
Stuart | | |
