| | | Forums66 Topics128,108 Posts1,056,236 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | What kind of parts you looking for? Everything is still available and sometimes are on the shelf for my 54 2 ton. CarQuest, NAPA or any other F.L.A.P.S. that's been around a while should be able to get anything you would need for a 60 - 66 era truck.
Our local powertrain store has several hydro-vac booster styles in stock. We also have a brake shop that can reline the shoes. Several machine shops can sleeve wheel cylinders and the cups are always a stock item at parts stores. The only thing that you may need to order would be a master and hoses. Scott | | |
