9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36608 09/16/2002 7:20 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you tried a different oil guage? Several other things could be the cause,worn bearings,weak oil pump,,, Try hooking up a newer oil guage in the engine compartment for a test and see if it shows a higher reading.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
