| | | Forums66 Topics128,163 Posts1,056,918 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36607 09/16/2002 6:43 PM | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | Something I have been noticing lately is that when the engine is idling and the tranny is in gear (not park or neutral) and I have my foot on the brakes, my oil pressure is about 5 psi or less. It doesn't seem to matter much whether the engine is hot or cold, but maybe a little worse when hot. It is a 307 with a TH350. Cold start-up pressure is 40-45, warmed up it is about 25. What would cause this to happen? Would it be a bad thrust bearing maybe, and above idle the oil pump is able to make up the loss of pressure?
Aaron | | |
#36608 09/16/2002 7:20 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you tried a different oil guage? Several other things could be the cause,worn bearings,weak oil pump,,, Try hooking up a newer oil guage in the engine compartment for a test and see if it shows a higher reading.
#36609 09/16/2002 7:34 PM | Joined: Sep 2000 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 67 | I do have an underdash oil pressure gauge on it right now, only about 2 years old. I have never had the bottom of this engine apart, so I don't know for sure what condition everything is in. I'm sure it could use some refreshening, but it runs pretty good other than this. I'm not too concerned because I am going to be putting in a new engine eventually and the truck isn't being driven much right now. I was just more curious than anything about the drastic change in oil pressure.
Aaron | | |
#36610 09/17/2002 2:05 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | What I believe is happening is when you put it in gear the engine rpm's are dropping and this is what is lowering your oil pressure. I wouldn't worry about it unless the pressure really gets low because it doesn't take much oil pressure ro give sufficient oil at idle.
kdot em3
