Originally posted by Charles in CA:
I had a difficult time getting an aftermarket air cleaner to fit the top of my Rochester 1bbl carb on my 37 Chevy pu w/56 235 engine. I ended up going to Winchester Auto Parts in Soquel and getting a tailpipe adapter and cut it down to fit. Just measure the opening in the air cleaner and the top of the carb & get pipe that fits. If they don't have it in stock, they can order it and have it there in a few days.
Hey Thanks Neighbor! I'm about 250 yds from Winchester auto! I'll check that out as an option,
One question though, I will need it to be diferent sizes on each end since it need to be an
extension riser going from the carb to the spacer. :p
