| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35698 12/12/2004 4:29 PM | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | Hello, Putting a small block in your '61 will require a little bit of work as the v8 bell housing is different and the motor mounts are also. I would look for a 63-66 C60 in a boneyard and rob the necessary parts although they are a little diff. than your 61 they will have the motor frame mounts and bell housing you need. Swapping out the old 235 is probably a good idea. If you do much hauling as it is way underpowered for a truck this size. Mike | | |
