5 members (baldeagle, Wayne67vert, klhansen, Joe H, Gray_Ghost), 92 guests, and 9 robots.
Topics128,019
Posts1,055,343
Members48,419
#35696 12/12/2004 6:27 AM
I have a 1961 c-60 that has a 235 engine that is smoking pretty good.Rebuilt 235 and 261's are hard to find and are big money if you do.I have a good 350 that I could put in, but how much trouble is this gonna be? Will it bolt up to the bell housing? What other problems? Would it have to be an older model 350, or say 327 or 283? Thanks for your help,Jim.
#35697 12/12/2004 4:24 PM
No, the bellhousing won't bolt up, but there are V-8 bellhousings available. Does yours have the hydraulic clutch with the throwout fork on the passenger's side? There is a bellhousing with the V-8 bolt pattern that is set up for the same clutch release arrangement, and the master cylinder, etc., will swap out OK. The manual-clutch variety has the throwout fork on the driver's side, and there is a pivot ball that screws into the 350 block just above the oil filter that allows the bellcrank to swivel. You'll have to fabricate an appropriate exhaust system, and do a little wiring and plumbing modification. The transmission, etc. will bolt up with no problems.
#35698 12/12/2004 4:29 PM
Hello,
Putting a small block in your '61 will require a little bit of work as the v8 bell housing is different and the motor mounts are also. I would look for a 63-66 C60 in a boneyard and rob the necessary parts although they are a little diff. than your 61 they will have the motor frame mounts and bell housing you need. Swapping out the old 235 is probably a good idea. If you do much hauling as it is way underpowered for a truck this size. Mike
