| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | its been a while since I worked on this model but I think its like the 37"s?? Is it truly the springs or is the "square hole" the handle goes through worn in one corner. IF it is you will have to build up that spot or do as someone here once said......they put the handle in a vice, heated it with a torch and "bent" it up some. Problem solved!!?? Just idea's Partzpllr, trying to help!! | | |
