| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32152 05/07/2005 3:40 AM | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | You'll need a different (as in BIGGER) radiator, ditto on the exhaust system. None of the accessory brackets like power steering, alternator, etc., from the 305 will fit, so get everything you can from the donor vehicle. Bellhousing bolt pattern will be the same, not sure about motor mount brackets. You might need a torque converter with a different stall speed, assuming the truck has an automatic trans. The big block will pull a lot harder at low speed, so a lower stall speed converter will make it work better. If it's a C-60, it's probably a stick shift, but if you can get a Turbo 400 with the engine, drop them both in there! Jerry
