| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29500 02/03/2005 7:42 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | So catch as much air as possible in the front and funnel it thru the rad. Got it. I'm 1/2 of the way there already. I mounted the new radiator (which is just a bit smaller than original) further back so I wouldn't have to use such a long fan spacer. So I've got 3"x20" vertical 12 gauge running up the sides that the rad. is mounted to. Just need to add a horizontal top and bottom piece to have a 3" wide front air catcher. I'll use aircraft sealant for any daylight. That stuff doesn't come off when our jets are flying 200, 300 knots and lasts a pretty long time. -David | | |
