| | | Forums66 Topics128,195 Posts1,057,380 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27265 07/11/2002 6:29 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If that's true, than the master cylinder needs adjustment or rebuild. The pushrod needs to be loose enough to let the fluid drain back into the reservoir leaving only 2 psi in the line when the pedal is released. The heat to the brake lines is bad, but it usually causes the brake fluid to boil leaving a lack of fluid, not pressure. Have him adjust the master cylinder pushrod and if that doesn't work the compensator port in the MC is plugged up.
