4 members (Stovebolt48, 1955 1 Series, Charles in CA, Otto Skorzeny), 122 guests, and 5 robots.
Topics128,193
Posts1,057,367
Members48,469
A friend has a 62' GMC car hauler that he recently bought. His problems have to do with his brakes. He recently replaced the rear drums on the tandem rear axle and I believe added new shoes front and rear. The newest problem that has come up is, the truck sat running for about 45 minutes. When he went to move it the brakes were frozen! He thinks that since the brake lines run with in 1/2" of the exhuast that the heat is warming up the fluid in the lines and then in the master cylinder, causing the brakes to lock up. He admits that it's a long shot but doesn't know what else could cause this problem
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe
1947 Chev Coupe
1969 GTO ragtop
If that's true, than the master cylinder needs adjustment or rebuild. The pushrod needs to be loose enough to let the fluid drain back into the reservoir leaving only 2 psi in the line when the pedal is released. The heat to the brake lines is bad, but it usually causes the brake fluid to boil leaving a lack of fluid, not pressure. Have him adjust the master cylinder pushrod and if that doesn't work the compensator port in the MC is plugged up.
Paint & Body Shop moderator
Does this truck have a Hydrovac system?there could be a problem with the hydrovac itself.
As 4onthefloor stated try adjusting the linkage to the push-rod at the master cylinder.I believe it should have 1/8th inch free-play.
